Fule pump problems!!!
Old Feb 2, 2007 | 05:47 PM
usmcgunman's Avatar
usmcgunman
Default Fule pump problems!!!
I have an 88 LX and my fule pump is acting up. When I turn the ignition on the pump comes on but when I turn it off the pump still runs. I have to disconnect the eletcical conector by the fule tank to turn it off. If the car is off for a long pieriod of time (over night) and I plug the conector back in it doesn't run but if I diconnector for short pieriods of time and the plug it back in it runs. Could this be the relay??? I have read that the relay is under the drivers seat but where(top of carpet, under carpet, under car under the seat)????? Anyone know if this will fix the problem?? If not what will??? Help please!!!! Thanks!
Old Feb 19, 2007 | 01:07 AM
usmcgunman's Avatar
usmcgunman
Default RE: Fule pump problems!!!
no one has any info?!?!?!?!?!
Old Feb 19, 2007 | 01:08 AM
Ninety5five0's Avatar
Ninety5five0
Do you have a repair manual of any sort ? That would help out a ton, it'll tell you exactly where it is.
Old Feb 19, 2007 | 01:10 AM
mattdel's Avatar
mattdel
is there anything else staying on? heater, radio, **** like that... if yes, probably ignition switch.
if not, its probably the relay. relay is located under the seat. whether or not its under the carpet, i dunno. i've never owned your car, so its hard to say
turn the key on, then turn it off. if the pump stays running, feel the relay. if its getting hot/is hot, its stuck on.
Old Feb 19, 2007 | 01:11 AM
Maxwelhse's Avatar
Maxwelhse
Sounds like a relay to me, but finding it is another issue. If all else fails, call the dealer or buy a book.
Old Feb 19, 2007 | 01:16 AM
mattdel's Avatar
mattdel
just unbolt the seat, its 4 bolts and 1 electrical connection if you got power seats. then the relay should be right in front of your face. i dont think ford would be dumb enough to put a wearable electronic device under the carpet.
Old Feb 19, 2007 | 01:22 AM
5.0 lou's Avatar
5.0 lou
ive had 2 fox's under the seat not carpet
Old Feb 20, 2007 | 07:20 PM
usmcgunman's Avatar
usmcgunman
Thanks for all the help! It was the relay after all. Took it off to take it to the auto part store and then had to put it back on to get there. After I reinstalled the car ran fine. Going to get a new one to have on standby.
Old Feb 20, 2007 | 10:55 PM
06Rubi's Avatar
06Rubi
Does anyone know if that relay controls only whether or not the pump works or what other functions it might control?
Old Feb 20, 2007 | 11:14 PM
93 LX FiveO's Avatar
93 LX FiveO
it tells the pump to turn on/off
