Quieting Down My Interior
Old Feb 6, 2007 | 12:10 AM
fox3's Avatar
fox3
Default Quieting Down My Interior
I'm installing new carpet in the my Fox, and I'm wondering if installing some sound deadening like DynaMat or FatMat is worth the cost. The stuff is $100 for 100 square feet. I'm not big stereo guy, but would like to quiet down the interior a bit. With open exhaust, and a mildly modified motor, the interior can get pretty loud.
Anybody tried this stuff?
Old Feb 6, 2007 | 12:29 AM
I3atR!ce's Avatar
I3atR!ce
Default RE: Quieting Down My Interior
the fatmat will help alot... i noticed a difference when i did mine. do yourself a favor and put a few lays on the floor, it will help alot.
Old Feb 6, 2007 | 12:35 AM
greenstreak9205's Avatar
greenstreak9205
just a suggestion but look on ebay for that stuff. you can get one hell of a deal for that stuff there. and if you're getting carpet and want to put that matting on also, to save some weight (not really much but every little bit helps) you can take off the padded backing
Old Feb 6, 2007 | 12:46 AM
GeraldineRyder's Avatar
GeraldineRyder
dyno mat works awsome, ive never used it because of exhaust but we ( the stero shop that i work at on the weekends) built a van and used dynomat on the walls, behind the headliner, and then foamed the pannels and ganed around 10 db. so it should keep sound out.
Old Feb 6, 2007 | 04:21 AM
bdc87's Avatar
bdc87
Try Second Skin it's the best bang for the buck it's less expensive yet better then dynomat. I plan on putting it in when I save up enough to redo my interior.
Old Feb 6, 2007 | 01:20 PM
boomerman's Avatar
boomerman
Try this stuff instead of the mats.
http://www.quietcar.net/
You do not have to cut any thing and roll it on, that gets to be a mess and makes your hands hurt after awhile.
No smell and it is so easy to put on.
I have used all the different types of mats out there and IMO this stuff is much better and cheaper.
I have done several cars with this and will not use anything else.
Old Feb 6, 2007 | 01:41 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
i dyno matted my truck for the road noise and my old mustang 98' because i have a huge system in it. i love dynomat. i used an off brand called bee quiet and it worked just the same and its waaaaaaay cheaper. i put two layers in door. 3 on floor and removed the padding in carpet. look wonderful and sounds so awesome. suuuuch a huge difference and make sure you apply heat after you stick it down. make its permanent. buy a cheap heat gun. also i cut my dynomat into 2" by 2" squares. makes it way easier to apply just more tedious and it looks nicer. PM me if you have any other ?'s
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
treesloth
Sep 28, 2015 07:03 AM
Shawmp
Sep 18, 2015 07:52 AM
