FUEL PUMP TO USE IN A 94 MUSTANG
Old Feb 6, 2007 | 02:32 AM
94gtmax50's Avatar
94gtmax50
Default FUEL PUMP TO USE IN A 94 MUSTANG
I HAVE A 94 MUSTANG BUILD ENGINE USING 30 LB INJECTOR WHAT IS THE RIGHT FUEL PUMP 155 OR A 190
-engine specs -
trick flow twisted wedged heads #51400002
61 cc combustion chamber
2.02 intake valve
1.60 exhaust valve
high rate valve spring 7,degrees lock manganese broze guides.
trick flow 1.6 roller rockers
--cam specs --
brand new trick flow track heat cam # 51402000
lift : 499 in intake / .510 in exhaust
duration : 275 intake / 2.79 exhaust
lobe separation : 112 degress
--add on to the engine--
cobra upper and lower intake manifold
bbk long tube headers
70mm throttle body edelbrock
76mm mass air C&L
30lb injectors calibratred
i should have 330- 350 to the wheel i dont know need i dyno tune
Old Feb 6, 2007 | 02:48 AM
94ford5liter's Avatar
94ford5liter
Default RE: FUEL PUMP TO USE IN A 94 MUSTANG
I just went with a bbk 225lph pump on mine. Because in the future when my engine goes out and I go to a stroker and a supercharger I dont have to change the fuel pump.
Old Feb 6, 2007 | 03:06 AM
Ninety5five0's Avatar
Ninety5five0
Go with a 255, it'll be there when your eally need it, and you have a fuel return line, so you can get too much fuel from the pump.
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
ShaneB26154
35
Mar 4, 2021 04:05 AM
MEISTERSNFB
Mar 31, 2020 07:50 AM
drumhedd2005
Aug 13, 2015 09:59 AM
89blueslug
Aug 10, 2015 07:20 AM
