driveshaft???
Old Feb 9, 2007 | 12:02 AM
banginstang07's Avatar
banginstang07
Default driveshaft???
Does anyone know how much the stock driveshaft weighs on a 94' gt??? just wondering since i am probably going to to get an aluminum driveshaft here soon...
Old Feb 9, 2007 | 12:26 AM
92hatchLX's Avatar
92hatchLX
Default RE: driveshaft???
If you have a surplus of money to spend on a drive shaft or your current d-shaftis vibrating after a ring and pinion install it's a good idea. Otherwise I'd just spend 15-20 dollars on new u-joints and call it a day.
Old Feb 9, 2007 | 12:43 AM
banginstang07
it's vibrating and the guy who did my dyno said thats what i need to fix the problem... but i just wondered how much weight i was losing i know it doesn't matter much but jw.
Old Feb 9, 2007 | 12:45 AM
92hatchLX's Avatar
92hatchLX
eh, maybe 10 lbs or so.
Old Feb 9, 2007 | 12:46 AM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: 92hatchLX
its a little more than that IIRC... I still have mine out in the garage... but its too cold to go out there right now
Old Feb 9, 2007 | 12:48 AM
ih8chevy's Avatar
ih8chevy
yea its actually a significant difference, i picked up an aluminum ds with one hand and i really couldnt pick up the oem one so, its at least25 lbs
Old Feb 9, 2007 | 01:11 AM
banginstang07
k thanx guys
Old Feb 9, 2007 | 03:49 AM
Twisted's Avatar
Twisted
ORIGINAL: AdderMk2
ORIGINAL: 92hatchLX
Also, it's spinning weight, which makes changing the driveshaft equivalent to shedding more weight than the shaft actually weights.
Old Feb 9, 2007 | 09:53 AM
bouchermb's Avatar
bouchermb
If you run at the track, every little bit of weight you can shed helps. If not, it's probably not worth the money.
Old Feb 9, 2007 | 10:41 AM
buget94gt's Avatar
buget94gt
what was you dyno numbers? just wonderin because i have almost the same set up.
