Ring and Pinion
Old Feb 9, 2007 | 05:34 PM
88 GT CONV's Avatar
88 GT CONV
Default Ring and Pinion
Hey guys, I'm about to pick up a brand new set of 3:73 gears, still in box (never used) for $50. I know better than to take his word for it, so what should I look for when i check them out? I want to make sure they are brand spankin new, and is there a way to tell if they are FRPP?
Old Feb 9, 2007 | 05:49 PM
Boss_Hotrod's Avatar
Boss_Hotrod
Default RE: Ring and Pinion
If they are ford racing they should be in a ford racing box (if they still boxed) and they will say ford on them like every other ford part.
Old Feb 9, 2007 | 05:51 PM
88 GT CONV's Avatar
88 GT CONV
Ok thanks for that. Where should I look for any damage or wear?
Old Feb 9, 2007 | 06:23 PM
88 GT CONV's Avatar
88 GT CONV
Someone help! I'm about to leave to get them right now! If there are things to look for that might not be obvious, let me know... thanks in advance
Old Feb 9, 2007 | 06:52 PM
red95gtconvert's Avatar
red95gtconvert
If they are new they won't have a wear pattern on them, look for shiny areas on the ring and pinion.
Old Feb 9, 2007 | 06:57 PM
89 fox's Avatar
89 fox
the threaded part of the pinion should be shiny from the nut tightened up
Old Feb 9, 2007 | 06:58 PM
89 fox's Avatar
89 fox
and the ring gear would have circles around the holes where it bolts to the carrier
Old Feb 9, 2007 | 07:13 PM
Glasersil's Avatar
Glasersil
And they will have a coating on them.
Old Feb 9, 2007 | 07:16 PM
gspfunk's Avatar
gspfunk
You'll be able to tell if they are used....they will have marks where the gears have meshed.
Old Feb 9, 2007 | 07:30 PM
HMUSN's Avatar
HMUSN
+1 on what everyone else said and this is what the box should look like in case you didn't know.. right down to part number
[IMG]local://upfiles/60440/9D62B9D1DCE146FBAE166B4BC9B7D614.jpg[/IMG]
[IMG]local://upfiles/60440/652988251D9B4FFEBA113687C1DBBF68.jpg[/IMG]
