cobra computer
Old Feb 11, 2007 | 02:45 AM
LIL D's Avatar
LIL D
Default cobra computer
would it be worth it to buy the 93 cobra computer for my 91 gt
Old Feb 11, 2007 | 03:12 AM
LIL D's Avatar
LIL D
Default RE: cobra computer
has anybody ever used this computer before
Old Feb 11, 2007 | 03:17 AM
notch5oh's Avatar
notch5oh
i'm almost positive it wont work without a new MAF and injectors
Old Feb 11, 2007 | 03:20 AM
LIL D's Avatar
LIL D
im going to be getting 24lbs injectors and a new maf but i heard the cobra computer was easier to tune because it already was setup for 24lb inject and a big maf
Old Feb 11, 2007 | 03:25 AM
notch5oh's Avatar
notch5oh
what heads/intake are you running?
Old Feb 11, 2007 | 03:38 AM
LIL D's Avatar
LIL D
cobra intake - gt40 heads
Old Feb 11, 2007 | 03:44 AM
vristang's Avatar
vristang
In order to run 24lb injectors on an A9* computer you need to ...
Lie to the computer about the airflow, via an aftermarket MAF.
OR
Get a custom tune on a dyno.
Most often the aftermarket MAF works out fairly well, never great, but pretty good.
Sometimes there are issues though; rough idle, hard cold start, etc.
Using a Cobra ecu will eliminate all of the negative consequences of running 24lb injectors.
The Cobra computer doesn't make 'tuning' easier, it eliminates the need for 'tuning'
Converting to the 93 Cobra computer requires a Cobra specific MAF/MAS and 24lb injectors. No other changes are needed.
There is no intrinsic performance advantage to using the 93 Cobra computer. Technically there may be a slight power loss, but it would barely be enough for a dyno to repeatably register.
I converted to the 93 Cobra computer a few years back to run 24lb injectors on my 302.
Good Luck,
jason
Old Feb 11, 2007 | 03:56 AM
LIL D's Avatar
LIL D
what kinda hp numbers can 19lb injectors hold to
Old Feb 11, 2007 | 04:51 AM
silver91gt's Avatar
silver91gt
300
Old Feb 11, 2007 | 04:53 AM
OnyxCobra's Avatar
OnyxCobra
if you want 24 lb injectors you shouldnt need a new maf, just the Cobra computer and 24lb injectors. That is, if it works the same as the '95 Cobras.
