Stalling problem
Old Feb 17, 2007 | 12:38 PM
89gfoxlx's Avatar
89gfoxlx
Default Stalling problem
I have an 89 5.0 with an automatic I just bought. The only thing I know for sure the motor has is the cobra intake and a/c eliminator kit. My question is in the morning when I go to leave it acts as if its carbureted or something. When I leave ifI punch it will spit and sputter and acts like its gonna die. It also vibrates like it has a bad miss till it warmsup. Now if i punch it and hold it and run it up till around 6,000 rpm then it clears up and runs fine. If anyone can give me any idea what might make it do this I would appreciate it. Thanks
Old Feb 17, 2007 | 12:53 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: Stalling problem
yeah dude that's smart rev'in a cold engine to 6k
Old Feb 17, 2007 | 04:59 PM
89gfoxlx's Avatar
89gfoxlx
I do it after it warms up if it wont clear up on its on
Old Feb 17, 2007 | 05:17 PM
90Lxstanger's Avatar
90Lxstanger
Sounds like it does it b/c itd COLD out,dnt worry mine does the same thing, if its fine when its warm, then you have no problems...........
go here- www.fordfuelinjection.com
read on how the whole EEC and its system works in relation with its sensors, maybe youll find something to help, maybe not good luck
Old Feb 17, 2007 | 05:58 PM
89gfoxlx's Avatar
89gfoxlx
ill check that out
Old Feb 17, 2007 | 06:54 PM
Stanpower's Avatar
Stanpower
Troubleshooting Intermittent Engine Problems, Larry Carley, August 2003
Old Feb 17, 2007 | 07:02 PM
decipha's Avatar
decipha
is your check engine light on? any codes? i would first check the fuel pump, also clean out the throttle body probably have alot of blowby in there
Old Feb 17, 2007 | 07:05 PM
90Lxstanger
Yeah check ignition first, have your check your cap and rotor? may be corroded, spark plugs? i know my car have 2 bad plugs and Bosch Platinum 2 made a world of difference.
good luck.........
uberstang1
Dec 7, 2017 07:10 AM
trashxtrash
Sep 20, 2015 10:49 PM
TfcCDR
Sep 14, 2015 12:08 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
tramphardrocker
Sep 13, 2015 08:56 PM
