Needing some help here
After changing out the Idle air control, adjusting my TPS to .98 volts, my car's idle still comes down way too slow. Could my TPS be a bad one or what.?I think that there's something else that is the problem here. I need any and all possibilities why this problem is still haunting me. Thanks guys
How slow is it idling? Is the throttle body dirty? (you can open the butterlfy valve with the engine off and look into it after disconnecting the breather hose) If there are no other problems and it's slower than you want, you could always consider adjusting the idle screw. What year is your ride?
ORIGINAL: 90GTRagtop
It idles fine once it's stopped. The problem I am having is in between shifts. When I push the clutch in, the rpms come down extremely slow. the car won't come to a complete idle until it is fully stopped. It's very strange. I have a brand new idle air control, so this is not the problem.
cardsrus1
19
Sep 15, 2015 08:37 AM
Sep 1, 2015 08:16 PM
