Upper Control Arm Bushings
Old Feb 24, 2007 | 04:00 AM
gspfunk's Avatar
gspfunk
Default RE: Upper Control Arm Bushings
ORIGINAL: Scout2232
ORIGINAL: notch5oh
maximum motorsports sells the original ford ones becasue they dont recomend using urethane in the uppers
Do they say why...??? I thought urethane is supposed to be the shizzle...
Poly supposedly doesn't allow the proper motion needed and can cause binding.
Old Feb 24, 2007 | 04:23 AM
kev2369's Avatar
kev2369
It only takes an hour to pull the rear end out of the car if you're afraid of using a torch under the car. But you can have them pressed out as well... I'd go with the 40 buck tool if i were you... Good luck
Old Feb 24, 2007 | 05:46 AM
Evil_F's Avatar
Evil_F
Just buy a set of arms with the bushings in them. You get new ones, and it is probably cheaper than getting bushings and tools. Plus easier.
Old Feb 24, 2007 | 05:48 AM
Scout2232's Avatar
Scout2232
ORIGINAL: Evil_F
Your avatar speaks volumes about you...
Old Feb 24, 2007 | 05:53 AM
Scout2232's Avatar
Scout2232
This is essentially what I got. Instead of the urethane bushings on one end, I have spherical ones. But the other end is the one with the stock sorry-condition rubber bushing that I need to replace.
[IMG]local://upfiles/36610/5B1DDCAAB3224FDFABA2675FB3C9EF91.gif[/IMG]
Old Feb 24, 2007 | 06:03 AM
Evil_F's Avatar
Evil_F
O'....
Old Feb 24, 2007 | 11:51 AM
Boss_Hotrod's Avatar
Boss_Hotrod
I was able to hammer one side out witha miini sledge. I had to hit it in one time then I just hit it out. The other side was a pain since I couldnt get the hammer in there. I had to use a drill and a sawzall. Ive heard of guys using an air chisel on them.
Old Feb 24, 2007 | 12:24 PM
silver91gt's Avatar
silver91gt
I just drilled a bunch of holes in the rubber, and pryed it out with a screwdriver.
poly upper mounts are fine with the spherical ends on there, they will allow the suspension to move
and energy suspension sells them, I had to get the whole C/A bushing kit, they dont sell just the upper bushings.
Old Feb 24, 2007 | 02:28 PM
Scout2232's Avatar
Scout2232
I checked and Maximum Motorsports sells the regular ford rubber ones, for like 40 bucks.Guess I'll buy those and some torque box reinforcements. All brands of torque box reinforcements are the same essentially right? Cause ones on ebay are like $100 cheaper than ones from UPR and look the same.
But yea, I agree with the drilling a bunch of holes like silver said.
Old Feb 24, 2007 | 02:40 PM
Boss_Hotrod
I think Summit sells the rubber bushing for $12.
