high flows cats installed.. car feels sluggish
well because my car wouldnt pass emissions with no cats and did bad on the tail-pipe test.. I had to RUIN my full mac exhaust(headers-back) with some cats. I went to a local exhaust shop and at first wanted them to connected the 2 cats with flanges so I could just put a testpipe after inspection and put it back whenever needed, BUT they quoted me $600!!!! **** THAT!!!.. It was $336 for the 2 cats and labor.... after picking it up after work.. I drove it home and the car was running horrible... does it just take time for the computer to adjust?? That is what the guy told me...
all I know is that my car doesnt sound NEARLY as good and kinda sputters a little when I punched it.
RE: high flows cats installed.. car feels sluggish
ORIGINAL: 93 LX FiveO
do you have 02 sensors? do they work?
what kind of cats did u buy?
not sure on the brand, but they are high-flow cats that they had there in the shop.
I do have the egr deleted, but it was deleted a long time ago and never gave me any problems before..
He told me to make sure I drive a minimum of 50miles before I go get inspected so the computer can readjust to the new cats(??)
The computer will not make ANY adjustments because of the cats. It can't, as the O2's are before the cats (unless the shop really f'd up your car...)
The 50 miles of driving is to 'break in' the cats. Brand new cats are actually a little less efficient. They need some good heat cycling to get into their prime.
It has nothing to do with the computer.
If the welder is smart, he disconnected your battery before working on the car. This would reset your KAM, so some time may be needed to get things back to normal. The 50 miles for the cats will be plenty for the KAM values to rebuild.
Pull your codes.
It is possible that they busted a sensor or something in the process of installing the cats.
IF the cats were not appropriately sized, then power loss can occur.
Properly sized cats won't cost you any power though.
jason
Pull your codes.
jason
alright.... earlier I decided on taking the car out for another spin.. this time the car was acting right... it didnt act like it did earlier... I'm going to reset the computer in the morning anyways. I am also going to drive to a friends house to break the 50mile mark before I take it to get inspected, or should I drive farther and get some exhaust flowing ;-)?
My car is lowered so I cant really see much unless I jack it up and look at his work. I saw the cats, but didnt look hard to see if there were o2's connected to the car. My egr is deleted and the header is capped. The CEL does come on, but when I run my obdI it only mentions codes regarging the egr.
The high-flow's dont hinder performance???
check the passenger side 02 sensor, see if they left it loose or used vise grips to tighten it, if so, replace it.
also if a torch was used, check the rear plug wires and associated 02 wiring
ORIGINAL: sipynsyrup
The cats MUST be appropriately sized though.
Are you confident your shop picked the right size? Are you sure you were given a decent brand?
I just realized that you had a 94. Since I am not very familiar with these cars, I will let someone else chime in here...
jason
alright thanks
would my obd1 pick up a bad o2?? What code would it throw, or what would the code say??
I am going to run the test tomorrow and also check to see if everything is connected. I am positive that a torch was used(they always use cutting torches to cut it off and weld it on. I hope he was smart enough to disconnect the battery while welding.
