Locking header bolts?
Old Mar 3, 2007 | 07:22 PM
live4motocross11's Avatar
live4motocross11
Default Locking header bolts?
what do u guys recommend? i was going to get stage 8 locking bolts but idk if i need 3/4" or 1"? or is there some other route i could go?
Old Mar 3, 2007 | 07:30 PM
fordguy17's Avatar
fordguy17
Default RE: Locking header bolts?
instead of bolts i now use studs. it make the install much easier because you just hang everything on the studs and then tighten the nuts.
i have also found that they are less likely to loosen up.
i switched to aluminum gaskets and my headers quit leaking too.
Old Mar 3, 2007 | 08:09 PM
turt's Avatar
turt
I use stage 8. Most headers are good with 3/4 unless your running a spacer, which Im sure your not. Headers can be a pain to install and I had to modify MOST of the locks to get them to fit this mustangbecausethe headers didnt give me a whole lot of room for fasteners. But I dont put headers on withoutlocking fasteners and anti-sieze on the threads.
Old Mar 4, 2007 | 12:37 AM
live4motocross11
ya well the motor is out of the car so it shouldnt b badand thanks guys, are wire locks good and where can u get them, i think adder has them
Old Mar 4, 2007 | 01:15 AM
tinman's Avatar
tinman
In 35+ years of using headers I've never used anything except regular header bolts with some anti-sieze on them if they are going to water jacket.
I've had just 1 bolt once get loose........
Old Mar 4, 2007 | 02:46 AM
redmustang83596's Avatar
redmustang83596
I use anti-sieze on ALL of my header bolts and I shoot at least one out everytime I take the damn car out. Im in the market for some locking ones eventually.
Old Mar 4, 2007 | 04:32 AM
house302's Avatar
house302
just use regular header bolts and some ultra black gasket sealant instead of a gasket and you wont have a problem with having to tighten them ever again. they come from the factory that way.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:58 PM
