what would you do?
i gotta block with 170k on it, and am taking the heads off, to get more power, also doing cam, i can get the heads i have now port and polished for close to free, is that worth it? or are they still not very good? how good are the gt40 Y? ...
RE: what would you do?
go with the edlebrock heads, best heads for a bolt on 302
also wouldnt eat for a while[:@].......... can you get to 300-350rwhp with gt40 heads and a bcam? with alot of bolt ons? or is it not worth it, and just get used afr's........... also i was wondering, i i just replaced the gaskets and put it back together to get it smoged, then i could get offroad heads... i was wondering if non smogable heads make bigger numbers?
I'd put a B cam in and P&P the stock heads... best bang for the buck
Any P&P job is well worth any money you put into it as long as you're not getting ripped. Letting more air flow and flow more freely is always a plus!
md, after i p&p stock heads, would they flow as good as g440 / gt40p? i hear the stock ones are pretty close to the worst heads there are:(
yea with a GOOD port job you should be able to equal or barely exceed the GT40's flow stock flow, if you get a GREAT port job with bigger valves you can get real close to the flow of edlebrocks
thanks alot md..... my goal is to get 300+ plus, and was wondering if this sounds like it would do it ... stock block / stock heads with alot of work / trick flow street intake / 70mm throttle body and egr spacer / under drive pullys / 73mm mass air / electric fan / long tube headers / catless x / 2 chamber flows .... sounds like alot, but im more than half way there:D i also know im going to need bigger injectors when going past 300
which cam would you be using?
not sure yet, but i want the biggest cam i can use with being able to pass cali smog, so far im thinkin bcam, but not sure, dont need to be a fms cam
