rear end?
Old Mar 14, 2007 | 02:43 PM
5.0ttop's Avatar
5.0ttop
Default rear end?
so i bought a 83 gt the other day and drove it to the house i noticed a couple of things... there is a whine that sounds like it is coming from the rear end what would be my best course of action to check on and fix this.
Also at about 65 mph there is a slight vibration from the rear of the car could this be coming from my drive shave which has multiple dents in it or is it more than likely associated with the rear end?
thanks in advance for the help
Old Mar 14, 2007 | 03:11 PM
5.0ttop's Avatar
5.0ttop
Default RE: rear end?
anyone?
Old Mar 14, 2007 | 03:21 PM
PJB's Avatar
PJB
A whine could be a bad wheel bearing, differential bearing or misaligned gears or even the tires.
Since your 83 has a 7.5 I wouldnt bother fixing it. Instead Id just swap in an '86 or later 8.8. Its a better rearend.
The vibration could very well be from the dented driveshaft or the U joints might be worn out.
Try to find a good driveshaft and put new U joints on it and see if the vibration goes away.
Old Mar 14, 2007 | 04:50 PM
5.0ttop's Avatar
5.0ttop
thanks i have been looking at an aluminum driveshaft anyway
as far as the rear goes would you get an 8.8 or go ahead and fork over the money for a 9 in?
Old Mar 14, 2007 | 04:53 PM
88BlueGT's Avatar
88BlueGT
Theres really no reason for a 9". A build 8.8 can be build to handle TONS of power... way more than a street car will ever need anyway. Save the cash and get yourself a 8.8 w/ gears already installed. You can usually get already geared rears for $300-400 dollars and sometimes cheaper if you find a good deal.
HACKGT350's Avatar
HACKGT350
there really is no reason to get the 9" an 8.8 can handle ALOT of power you would be better off getting the 8.8 unless you can find a 9" for real cheap
Old Mar 14, 2007 | 05:53 PM
5.0ttop's Avatar
5.0ttop
any ideas on where to get a new 8.8 with 3.73's?
Old Mar 14, 2007 | 06:40 PM
PJB's Avatar
PJB
Id just pick up a junk yard rearend and put all new bearings and seals and new gears in it.
Old Mar 14, 2007 | 06:51 PM
88BlueGT's Avatar
88BlueGT
+1 Check forums, local newspaper listings, ebay, craigslist, etc. Check out people who are parting out their cars, etc.
Old Mar 14, 2007 | 06:56 PM
5.0ttop's Avatar
5.0ttop
alright i appreciate it
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
