PROBLEM?
Did you replace the filter too? You got a bad pump, you have a restrictive line or crap in the tank or resistance in the pump wiring. Odds are, the pump is good. If you did it right, you should have noted any crap in the tank and replaced the filter. This makes the most likely source of your issue some resistance in the pump wiring. This limits the pump's top speed and consequently, it will not be able to provide enough pressure/volume.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
