MUSTANG FORUMS TEAMSPEAK SERVER (Voice Chat)
Ok everyone, I figured I'd rent a server for a month to see if people here take to it..... if you all like it I'll keep paying for it. (donations gladly accepted )
the IP is 209.160.40.21:9127 and there is no password
you can download the software for free at:
http://www.goteamspeak.com/index.php?page=downloads
(Teamspeak 2 Client Version 2.0.32.60)
It's alot better than constant posting and reposting for all you that frequent the forums, also I will give all moderators on here server admin and contributors channel admin.
How To Connect
Once you open the program click "connection" and then "connect"
Anywhere in the big white box right click and then click "add server"
Label: Mustang Forums
IP field: 209.160.40.21:9127
Nickname: Your user name
Anonymous should be checked
Click "connect" at the bottom and your in.
Register Yourself
Click on " self " and then "register with server". Enter your username and choose your own password. Next time you want to connect to the server, click Registered instead of Anonymous and enter your username and password.
Troubleshooting
If you login to the server and you cannot talk and you know your mic or headset should be working, or if you can't hear at all - click "settings" and then "options" and make sure your sound card is selected under "input device" and "output device".
Another thing to check is under "settings" and then "sound input / output settings". Make sure either "voice activation" is checked, or "push to talk". if push to talk is checked make sure a key is set for it to work.
Moderators, can someone please make this an announcement or a sticky?
How To Connect
Register Yourself
Troubleshooting
ORIGINAL: 93 LX FiveO
TS is trash
ventrilo ftw
TS is trash
ventrilo ftw
thanks 2 kwik
if its empty and you can, just idle down at the bottom. people come in and dont see anyone so they leave, but theres like 20 people so far that use it from time to time.
