need help!!!!!!!!
so we got the cam in the timing set and got her started up tonight we ran it at 2000 rpm to break the cam in for 30 minutes but my question is why when I go to rev it is it going so slow like it has no nuts anymore will a tune fix this because I know I have to get it tuned anyway?????????????????????
Yeah', basicly. Seeing you asked "what do you mean". That is probably your problem. If you dont recheck your cam angle with one of those dials. You have to be very carefull to put it back in at the exact angle you pulled out the stock one.
ORIGINAL: gizim_1132
1. What cam did you install?.....specs are?
2. Did you degree it?....
3. Did you check your spark initial timing?
they probably just installed it and didnt bother turning the motor over twice to see if it stayed lined up after the slack was taken up out of the timing chain....
I love when newbs screw up their motors!
Well you got to learn somewhere and it's not gonna be by doin everything righton the first try!!!!!!!!!!!!!!!!!
