mass air question
mass air question
i just bought a 1989 mustang lx notch that was transplanted with a 5.0 it ran when i got it it seems to be done right and clean it didnt have oil pressure so i took it out and stroked it new aluminum heads bbk ssi intake 30lb inj 80mm throttle body , custom cam what concerens me is the car had no mass air sensor or wire where it should be. my question is does it need it or did someone not put the right harness in it . I assume it is a v8 harness due to the fact that it has 8 injector wires and it ran good any help would be great thanks
RE: mass air question
Catch code should read A9L or A9P if it is a MAF computer. Not sure what an SD code might be though...
It will be 3-4 digits, and should be in larger text/bold text, when compared to everything else.
jason
jason
i looked at the computer and the numbers were as followed eec-IV under that was sfi-sd3 then to the right of those was E8SF-12A650-A1C and upper right corner read 8KC if this any help to you great thanks alot for your help
ORIGINAL: hunter5.0
