nitrous ???
ok i just purched a nitrous works adjustableefi wet plate system . i ahve a couple of ??? i need to figure out 1st -do i need to have a fuel pressure saftey switch since its a wet system 2nd will i stil have to run a higher fuel pressure i have 24 lb injectors and with the wet system it spays both gas &nitrous ?they might be stup*d but i just want to make sure that i dont have any problems thanks
a cuttoff switch is a must for safty and keep your engine alive and you will need to up grade you fuel pum injectors and regulator awsell so you car can deliver the necessary fuel requirements is need when its on the bottle
yes safty switch is a must if you drop fule press and dump alot of nitrous in the enigine you can burn a pistion up
nitrous adds cold air to you air and if youdont all the same amount of fuel to it it will run really lean when it on the bottle and if you lose fuel press while on the bottel you can burn a pistion up or burn the rings up
The fuel pressure safety switch comes into play if your fuel volume is inadequate or your fuel pump fails while you're on the bottle. Your fuel system is adequate. So buying the switch will save your motor from having the nitrous lean it outIF the fuel pump fails WHILEyour on the bottle.
I don't run fuel pressure safety switches. I build adequate fuel systems.
yeah if it's a new pump, and new inj your fine. good piece of mind for $15 though, look on ebay and search on fuel pressure safety switch.
no you don't need to spike your fp at all.
retard your timing to about 10* for 100-125 jets
close your plugs to about .035"-.040"
