Oil Motor/Tranny?
Old 03-23-2007, 01:13 PM
Ford LX
Ford LX's Avatar
Default Oil Motor/Tranny?
I have a 89 Mustang LX wtih 155000m, Have now 5 W 30 Mobil 1 in Motor is that OK?
what kind of Transmission fluid you can recommend I know its have to Mercon 5! When I shift from the 2th to 3th in higher Rpm Its grind sometime so I have to double clutch!! Its now Valvoline in it.
Thanks for Help
Ford LX is offline
Old 03-23-2007, 02:03 PM
LTnone
LTnone's Avatar
Default RE: Oil Motor/Tranny?
10w30 is stock, is that Mobil 1 synthetic? You will want a synthetic oil at that mileage. Sounds like you have a T5, MERCON ATF is the stuff you want for your trans.
LTnone is offline
Old 03-23-2007, 05:31 PM
Ford LX
Ford LX's Avatar
Yes it is Syntethic. So would be better to change to 10 W30? What brand do you recommend for tranny? Cause since the Valvoline is in it, I have the Problem!
Ford LX is offline
Old 03-23-2007, 05:33 PM
primetime5.0
primetime5.0's Avatar
isnt stock 5w30?, tranny takes atf mercon 3. I use plain old 10w40 and have syncromesh in my trans.
primetime5.0 is offline
Old 03-23-2007, 05:36 PM
Ford LX
Ford LX's Avatar
I thought too 5 W 30 is stock! What Brand for Tranny Royal Purple?
Ford LX is offline
Old 03-23-2007, 05:41 PM
primetime5.0
did you just start using synthetic since you bought the car? or has it always had it? royal purple makes good fluids
Old 03-23-2007, 05:50 PM
Ford LX
Ford LX's Avatar
Yes It was the first oil change!
Ford LX is offline
Old 03-24-2007, 05:22 AM
primetime5.0
you should have stayed with regular oil, or a high milage one
wraith777
09-28-2015 10:49 AM
Shadow7874
09-24-2015 09:06 PM
belam
Oil and Oil Related Topics
09-23-2015 11:29 PM
Demodulates
09-18-2015 11:14 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: Oil Motor/Tranny?
