400 hp
Old Nov 13, 2004 | 02:23 AM
elilund's Avatar
elilund
Default 400 hp
What is the cheapest way to get to 400 hp at the crank with a small block. Complete crate engine? Short block? Thanks for the help.
Old Nov 13, 2004 | 02:28 AM
bobby's Avatar
bobby
Default RE: 400 hp
400hp from a 302? 331? 347? ...............
Old Nov 13, 2004 | 02:35 AM
elilund's Avatar
elilund
Default RE: 400 hp
302,331 or 351.
Old Nov 13, 2004 | 02:46 AM
bobby's Avatar
bobby
Default RE: 400 hp
302 its gonna take a lot. Heads, cam , intake, etc. but you can do it N/A. 331, tou can just do all the bolt ons, 351, would take a whole lot to get there, im not sure what ou want to do, blower, nitrous, etc?
Old Nov 13, 2004 | 03:04 AM
elilund's Avatar
elilund
Default RE: 400 hp
What would be the cost to build a 331?
Old Nov 13, 2004 | 03:16 AM
luckythirteen13's Avatar
luckythirteen13
Default RE: 400 hp
depends on what you do....afr heads alone are $1300
Old Nov 13, 2004 | 04:34 AM
94Cbra's Avatar
94Cbra
Default RE: 400 hp
400 Crank HP on a 302 isnt that bad. Just grab some forged pistons and connectors (for 93+ stangs), then load that bish up with some N20 . N20 is gonna be by far the cheapest way to aquire that 400 crank HP your looking for. Dont forget to upgrade your Tranny though, it would be fine for street but, as soon you smack some slicks on, that tranny is gonna be pissed!
Old Nov 13, 2004 | 04:50 AM
Quik's Avatar
Quik
Default RE: 400 hp
a JYTT setup can be built for 1500 bucks that will get you over that number
Old Nov 13, 2004 | 10:16 AM
FoxGT's Avatar
FoxGT
Default RE: 400 hp
If you have to ask what it takes to get 400hp, you don't have what it takes to get there!
Old Nov 13, 2004 | 02:24 PM
roundman's Avatar
roundman
Default RE: 400 hp
you need to consider the total package in order to get to 400 HP at the crank. this means the cam, heads, intake, exhaust, injectors, fuel pump, etc. all have to be selected to work together to put out the HP you want. call the Ford Racing parts tech line at 586-468-1356 and they can give you some good advice on what pieces will get you there.
