Hydraboost Swap
Old Mar 28, 2007 | 03:14 PM
ddeaton66's Avatar
ddeaton66
Default Hydraboost Swap
Anyone done this on their fox? Search only turned up 2 minimal posts...
Tia
Old Mar 28, 2007 | 06:06 PM
ddeaton66's Avatar
ddeaton66
Default RE: Hydraboost Swap
Bump
Old Mar 28, 2007 | 08:22 PM
ddeaton66's Avatar
ddeaton66
one more time
Old Mar 28, 2007 | 08:29 PM
notch5oh's Avatar
notch5oh
what the hell is it?
Old Mar 28, 2007 | 08:31 PM
ddeaton66's Avatar
ddeaton66
96+ use the power steering pump to boost the brakes instead of a vacuum booster. Works great and saves alot of room. Common sense tells me it'll just bolt up...but, I would love to see a build or sticky on it from someone who has made the swap to get all the little details.
Old Mar 29, 2007 | 01:03 PM
ruger311's Avatar
ruger311
i would like some more info on it also, currently with eht 347 build im pulling only 9-11" of vacuum and cant power my brakes very well, cent even lock em up, tried the canister things, works a lil not good enough if i cant lock them up, im going to either buy a ele vacuum pump or do the hydroboost,,,, anyone have info on these, damned electrics are noisy
Old Mar 31, 2007 | 01:36 PM
SurWicked's Avatar
SurWicked
i was going to try this but if the car dies or you throw a belt what are you going to do? i wanted to do this also to avoid manual brakes. right now i just turnned up my idle to ~1200 rpm so i can have 8 inches of vac.
Old Mar 31, 2007 | 02:02 PM
ruger311's Avatar
ruger311
all we can do is use bigger brake boosters or get ele vacuum pumps or do the hydroboost thing
Old Mar 31, 2007 | 02:05 PM
SurWicked's Avatar
SurWicked
i was told that vac pumps dont last very long, they are more or less intended for "race cars" kinda like a electric drive water pump.
Old Mar 31, 2007 | 03:20 PM
ruger311's Avatar
ruger311
the ele vacuum pumps will run until it reaches around 20-22" vacuum then it shuts off until it senses under 15" vacuum then it comes back on, a lot of people are using them ive found out, i guess if it only lasts so long thats the price we pay for good brakes, ive got a couple more things to try b4 i throw down 279 for an ele pump but if that is what it comes down to so be it
