Compression Question
There can be many different reasons. Pistons, head gaskets, etc. The compression of the motor has nothing to do with it being a stroker. You can set up a 306 to have14:1 com or a 348 to have 8:1 compression.
Yea, you can set your compression up to whatever you want it to be. For ex... if someone was building a stroker motor that they planned on boosting most would opt for an 8.5:1 comp or lower. If building a NA car most will go for 9.5:1+
I would be suspect that it is 11-1 compression
unless the heads have been milled or you have dome pistons
with 0 dish flat top pistons and 58cc heads on 306 will have 10.5 -1 compression
ORIGINAL: my77stang
whats up with the 6.75 pushrods in your sig? that makes no sense / means nothing?
rotated the valves around. Actually I thought they used 6.70 pushords
