engine swap help
Old Nov 18, 2004 | 02:44 PM
90lxCoupe's Avatar
90lxCoupe
Default engine swap help
hey!
im planning to swap the engine out of my 90 lx notch AOD pretty soon. I was just wondering would it be cheaper or easier to swap the engine and tranny for a carburated engine say from an 85 gt than a(87-93) engine and tranny.
help me if you can and thank you for your time
Old Nov 18, 2004 | 04:40 PM
nemethjames1's Avatar
nemethjames1
Default RE: engine swap help
if your goiing to be getting an engine, i think the years 87-93 are made better..., it would be cheaper going to a carb setup, but i prefer EFI, its a great system once its going right
Old Nov 18, 2004 | 05:21 PM
Quik's Avatar
Quik
dont use a 85 motor. if any use 87 to 92 motors.
Old Nov 18, 2004 | 05:38 PM
luckythirteen13's Avatar
luckythirteen13
87-92 and just put on a carb and manifold to fit
Old Nov 18, 2004 | 07:59 PM
bobby's Avatar
bobby
what about 93 i knwo i knwo lol, keep the EFI!!!!!!!!!
Old Nov 18, 2004 | 08:01 PM
94Cbra's Avatar
94Cbra
no forged pistons in 93 .
Old Nov 18, 2004 | 08:06 PM
bobby's Avatar
bobby
i know if your not doing a power adder ur fine, even a small shot (50) shot ull be fine
ORIGINAL: 94Cbra
Old Nov 18, 2004 | 10:57 PM
87mustang347's Avatar
87mustang347
id say stick with the efi. way more relable then a carb setup
Old Nov 19, 2004 | 12:15 AM
nemethjames1
carb is easy, cheap and you get a good amount of hp, but you'll be turning screws once a week to get it right..... efi its either missing or running perfect lol
Old Nov 20, 2004 | 03:12 AM
roundman's Avatar
roundman
if you convert to a carb setup, you will need a different fuel pump and regulator plus a new ignition systems as the ECU won't be there to handle the ignition either, so I wouldn't say swapping to a carb setup is cheaper than keeping the EFI you already have. keep EFI and it's just plug in and play. go with carb, lots more work to do in order to play.
Nick Oliver
Oct 17, 2018 04:22 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
