Fuel Line ?
Old Apr 2, 2007 | 10:58 PM
bighungrymatt's Avatar
bighungrymatt
Default Fuel Line ?
I'm having trouble disconnecting my return fuel line, in order to tap in with the FMU that came with my supercharger. Does anyone have any advice to using the spring lock disconnect tool? I'm finding it real difficult to disconnect. Thanks guys.
Old Apr 2, 2007 | 11:03 PM
LTnone's Avatar
LTnone
Default RE: Fuel Line ?
Put it on the line, and push it into the connection. You'll feel it click, which means that the spring is out of the way. Keep pressure on it and pull it apart. Done.
Old Apr 3, 2007 | 12:40 AM
bighungrymatt
hmm, I tried to do that but it would never click, maybe I had the wrong sizetool (even though the the box said it would work on ford 80-current)
I will try again tomorrow, thanks
Old Apr 3, 2007 | 12:44 AM
93must's Avatar
93must
Push the lines together and hold them while you put the tool in. Once you slide the tool in pull them apart.
Old Apr 3, 2007 | 12:49 AM
LTnone's Avatar
LTnone
Even if you can't hear it click just push it in as far as it will go and try to pull the line apart.
Old Apr 3, 2007 | 12:52 AM
1995mustang818's Avatar
1995mustang818
make sure its the right side i had the same problem could not get it to disconnect figured that out like a min later tryed the other side of the line came out lol
Old Apr 3, 2007 | 01:03 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Sometimes twisting the line helps too.
TCStangerv6
Oct 11, 2015 05:57 PM
Sixx
Oct 5, 2015 07:36 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mrappe
Sep 26, 2015 10:16 AM
