Valve adjust help
Old Apr 3, 2007 | 05:56 PM
TTGreenSN95's Avatar
TTGreenSN95
Default Valve adjust help
I just went around the block a few times after the hci swap
seems one of therocker arms worked itself loose and tapping.
valves seemed to chattter alot at high rpm.
I went 3/4 turn after valve was closed to adjust them
do I just need to go half a turn???
how do you guys adjust your valves???
I have 1.6 crane steel roller rockers.
with the poly locks
1994 stang
Im going to reajust them all just wondering how many turns you guys go on yours?
Old Apr 3, 2007 | 06:26 PM
LTnone's Avatar
LTnone
Default RE: Valve adjust help
Between 1/2 and 3/4 after zero lash is fine. Did you turn the allen head locking nut on the top of the rocker (if equipped)?
Old Apr 3, 2007 | 07:28 PM
my77stang's Avatar
my77stang
yeah 1/2 is a happy place. i always hear between 1/4 to 3/4 so 1/2 seems perfect.
Old Apr 3, 2007 | 08:43 PM
TTGreenSN95
Yes I turned the waazo out of that locking allen head lock im thinking 3/4 might have been to much ima go half the next time
thanks for the help!!!anyone disagrre with half let me know before the night is over thanks agian
Old Apr 3, 2007 | 09:24 PM
Arrid Extra Dry's Avatar
Arrid Extra Dry
depending on what kind of rocker arms you have and legnth push rods, could be 1/4 1/2 3/4
all rocker arms are different
GimpyHSHS
19
Dec 19, 2023 01:12 PM
cr620
Oct 3, 2022 10:18 PM
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
