Fuel????
Old Apr 8, 2007 | 10:44 PM
baysideblues's Avatar
baysideblues
Default Fuel????
My fuel pump is starting to go out and i want to get a 255 but my question is do i need to get a fpr with that to or not. I plan on just doing bolt ons with some juice so should i go with a smaller pump? Also what are some good fuel rails and injectors for what im doing i was thinking 30's? Thanks guys
Old Apr 8, 2007 | 10:47 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Fuel????
ORIGINAL: baysideblues
Yes on the afpr but you won't need any of the other stuff you listed until you gry some serious mods goin.
Old Apr 8, 2007 | 11:08 PM
baysideblues
thanks
Old Apr 8, 2007 | 11:13 PM
luckythirteen13's Avatar
luckythirteen13
are you buying a wet kit or a dry kit? if dry id get 24-30# injectors depending on the mods you have planned for the future but if your getting a wet kit, then the stock injectors will be fine untill you do h/c/i. the rails are a waste of money. your stock rails will feed more hp then the stock block can handle. and the 255lph pump will be fine. any fuel not used will just go right back to the tank
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
