5 lug conversion
Old Apr 9, 2007 | 06:34 AM
5.0_Cobra's Avatar
5.0_Cobra
Default 5 lug conversion
Alright so i have an 84 lincoln mark 7 just sittin at my house and was wondering if i could use the front brake assembly for a 5 lug conversion? I already have 5 lug rear axles for my car so would the rear brake assembly for the lincoln bolt up? Need as much help as possible. Thanks
Old Apr 9, 2007 | 08:34 AM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: 5 lug conversion
http://www.sn95brakes.com/4lug.php
Old Dec 30, 2007 | 09:59 AM
50mustang's Avatar
50mustang
i have 88 lincoln rotors on mine and that bolted right up you can even use the calipers as well they will give you more stopping power
Old Dec 30, 2007 | 10:14 AM
mustang35190's Avatar
mustang35190
I have the lincoln rotors on the front of my 90 notch, only problem is with cobra r rims and maybe a few others,
the cap that covers the castle nut and lock pin, pushes the center cap out on the rim. So I pulled the front spindles
and brakes along with the rear disk brake system along with all hard wareoff of a 96 gt, paid 80 bucks at the local pick and
pull should work nicely, hope it helps.
Old Dec 30, 2007 | 10:35 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
https://mustangforums.com/m_4392132/tm.htm
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
Oct 7, 2015 07:02 PM
DCole24
Sep 11, 2015 10:50 AM
