tps?
Old Apr 11, 2007 | 04:17 PM
91ford302's Avatar
91ford302
Default tps?
when i start my car and it idles down it sits at like 1k for 2-3 minutes, then it drops and surges violently. it will jump down so the tach shows its at like 200 rpm then back to 800 up and down. I was told that this might be my IAC, but i cleaned it out and its still doing it. Can it still be the IAC or is it maybe the TPS? How can i tell besides buying new ones? Also on some cars I know the tps can get out of adjustment and using a multimeter you can adjust the tps to read the right voltage or w/e and it will work better. Is the 5.0 tps like this? if so how do i do that? thanks for the help.
Old Apr 11, 2007 | 04:21 PM
1990boostang's Avatar
1990boostang
Default RE: tps?
My buddies does that when the MAF is unhooked. he has a 1992 gt and MAF clip is broke and sometimes the connector will slide off and starts loping like that.
Old Apr 11, 2007 | 04:25 PM
91ford302's Avatar
91ford302
Default RE: tps?
my MAF is connected, i know it works because i had the tube between it and the tb off and started the engine one day. very violent surging, once i popped the tube back on it went away. Unless its only working partly.... I hate electronic crap.
Old Apr 11, 2007 | 05:29 PM
00limited7's Avatar
00limited7
Default RE: tps?
I sent you a PM check your inbox.
Old Apr 11, 2007 | 05:32 PM
scbmx87's Avatar
scbmx87
Default RE: tps?
It could be the TPS, mine surges lightly, but I haven't cleaned anything yet.
ShaneB26154
35
Mar 4, 2021 04:05 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
bmorrisj
May 27, 2004 06:18 PM
