No Heat
Old Apr 11, 2007 | 07:09 PM
SweetLou's Avatar
SweetLou
Default No Heat
Hello all, I am new to Mustangs. Just picked up a 93 5.0 yesterday. Everything seems to be in a good shape for the most part. Found that the A/C blows cold, but there is no heat. The selector switch for the cold/hot rotates completely around. Not sure if replacing that would fix it, and if it is just 1 big unit for everything, or 3 individual units behind there. Any advice would be great.
Thanks!
Old Apr 11, 2007 | 07:11 PM
1985stang's Avatar
1985stang
Default RE: No Heat
Well, i don't know about the **** turning all the way around. If you don't get heat though, that means you need a new heater core.
Old Apr 11, 2007 | 07:24 PM
50Trippin's Avatar
50Trippin
Default RE: No Heat
The cold/hot selector runs a small cable, so if it's turning all the way around the **** is broken or not hooked up to the cable.
Old Apr 11, 2007 | 07:26 PM
86_GT_Mustang's Avatar
86_GT_Mustang
Default RE: No Heat
nice car but make it smaller^
Old Apr 11, 2007 | 07:27 PM
50Trippin's Avatar
50Trippin
Default RE: No Heat
workin on it. first time i posted with it in sig.... sorry.
Old Apr 11, 2007 | 07:30 PM
scbmx87's Avatar
scbmx87
Default RE: No Heat
Heater core for the no heat problem, cable or **** is broken too.
Old Apr 11, 2007 | 07:33 PM
LEVINEMN5.0's Avatar
LEVINEMN5.0
Default RE: No Heat
ARE U OVER HEATING???????
Old Apr 11, 2007 | 08:21 PM
deanzawistowski's Avatar
deanzawistowski
Default RE: No Heat
how high does your temp gauge go up? if the person before you put in a 160 thermostat it would make the heat not work very well. Before getting into heater core replacement id check the thermostat
Old Apr 11, 2007 | 08:33 PM
SweetLou's Avatar
SweetLou
Default RE: No Heat
Drove it about 5 hours yesterday, stays right about the middle of the temp gauge, doesn't overheat at all.
So what I need to look at is replacing the control switch, and the heater core?
Old Apr 11, 2007 | 08:43 PM
Drexl's Avatar
Drexl
Default RE: No Heat
screw heat.. these are summer cars
