how hard
Old Apr 11, 2007 | 09:03 PM
jerrylee01's Avatar
jerrylee01
Default how hard
how hard would it be to change clutch in my 85 gt ? never done 1 before but other night went out and playing and burned tires off but also smelled little bit of clutch also . and then later on while car was still warm tryed to power brake it and said no deal everytime rived and dumped clutch was like car fell on its face. but later on when was cooled off i could light tires back up like nothing so think might be time for new 1
Old Apr 11, 2007 | 09:06 PM
onebad88's Avatar
onebad88
Default RE: how hard
easy...just drop the tranny, unbolt the prssure plate,i wouldget the flywheel turned(resurfaced),install new clutch and pressure plate(make sure its lined up, re-install tranny
Old Apr 11, 2007 | 09:08 PM
luckythirteen13's Avatar
luckythirteen13
ORIGINAL: jerrylee01
OMG!! who taught you to speak english?
anyways, its not hard but if youve never done it before plan on spending some time on it
1985stang's Avatar
1985stang
Yeah sounds really easy. I'm just gonna avoid this problem by not doing sh*t like that.
Old Apr 11, 2007 | 09:09 PM
jerrylee01's Avatar
jerrylee01
thanks i didnt think it would be hard but wasnt sure bout it never done one and dont know **** bout them lol.
Old Apr 11, 2007 | 09:16 PM
jerrylee01's Avatar
jerrylee01
speak english can u read ? do i have to use periods for you to understand some things. dont have any problems out of any other guys on here bitching bout that if i ask something they help and im glad they do. but you this isnt 1rst time you have said that **** bout one of my questions so luckythirteen13 if your gonna complain bout my questions and way i type dont even help me out here im sure these other guys can help me out . but thanks anyways
Old Apr 11, 2007 | 10:07 PM
Stanpower's Avatar
Stanpower
[quote]ORIGINAL: jerrylee01
[/quote Ya ,the clutch worked again because it cooled down? It's probally ok but, NOT a good idea to be smoking the tires like that..Crazy! It will cost you more than just a clutch if you keep doing things like that.....Good Luck! If you never did a clutch before best to take it to a shop less headaches but more money$$$
Old Apr 11, 2007 | 10:13 PM
91stang's Avatar
91stang
maybe you should be a little easier to your car too. it sounds like you rough her up a lot
Old Apr 11, 2007 | 10:32 PM
jerrylee01's Avatar
jerrylee01
ruff her up nah lol jus like to have some fun sometimes but take it little to far sometimes but is time to quit the 1/4 mile burn outs lol tires cost to damn much but ones had on it was jus stockers. but i know its hard on clutch and tranny and thats another reason im done i can afford clutches but tranny's they dont come cheap
Old Apr 11, 2007 | 10:38 PM
scbmx87's Avatar
scbmx87
I just put one in my 86 GT last weekend. Take your driveshaft off, put a jack under the tranny, unbolt the crossmember, unplug all of your sensors on your tranny, remove the four bolts connecting the tranny to the bellhousing, remove the bellhousing from its cover(starter too), remove clutch fork and throw out bearing, remove pressure plate and clutch disc, get flywheel resurfaced, put flywheel back on, put pressure plate and clutch disc back on, align it with clutch alignment tool, tighten pressure plate bolts to spec, reinstall bellhousing, replace throw out bearing and reinstall clutch fork, reinstall tranny and tighten the four bolts back to spec, reinstall sensors and connectors to tranny, reinstall crossmember, reinstall driveshaft, and last but not least...STOP BEATING THE **** OUT OF YOUR CAR!!!
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
wraith777
Sep 28, 2015 10:49 AM
