good setup
Old Apr 14, 2007 | 07:23 PM
scooterstang's Avatar
scooterstang
Default good setup
i hate these threads, but when your bored you can't help but think about it, so maybe someone else bored can answer this for me
im doing a 347 stroker, do these mods sound good?
afremission legalheads
trickflow stage 1 cam
performer intake
255lph fuel pump with regulator
4:10 gears
1.7rr
full exhaust
and mods in sig
Would you change anything or add anything to this list of mods.
What kind of power or what do you think it could run if i can drive?
its an aod
Old Apr 14, 2007 | 08:17 PM
jtmustang's Avatar
jtmustang
Default RE: good setup
just some info but a 347 i would definetely be runnin some other kind of cam good cam but a 347 could use a lot bigger cam to get the max potential out of it other than that u should have a good motor.yeah im bored to raining here in washington not d.c.
Old Apr 15, 2007 | 05:42 AM
scooterstang
i was talking to this mustang guy that came into my work today. he suggested a set of canfield heads and a custom cam. obviously a custom cam would be much better, but im on a very small budget. is the custom cam worth saving for, and what do you guys think about canfield heads?
Old Apr 15, 2007 | 05:49 AM
MadMan@TheWheel's Avatar
MadMan@TheWheel
I have heard good and bad about them. Like all the others. Heads have followings, if you have not noticed.
5literchevyeater's Avatar
5literchevyeater
afr and canfield are both great heads but you really just need a bigger cam not so much a custom one but that tfstage 1cam is not anything you want budget or no budget car will perform much better with a bigger cam and you need one
Old Apr 15, 2007 | 06:30 AM
stangman94's Avatar
stangman94
Might wanna add some bigger injectors
Old Apr 15, 2007 | 12:33 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
cam isn't emmision legal
Old Apr 15, 2007 | 04:00 PM
scooterstang
does anyone have a good idea of an emission legal came that will not take is not as expensive as a custom? it will be mostly a daily driver and a stoplight racer, but it will see track time about once a month or less
Old Apr 15, 2007 | 04:04 PM
my77stang's Avatar
my77stang
heres what i dont get..... why buy a cam then 1.7 rockers?
if you need 1.7 rockers to get the power you want from the cam, you didnt buy the right cam!
derrr!!!!
Old Apr 15, 2007 | 04:16 PM
Maxwelhse's Avatar
Maxwelhse
Good motor mounts and a decent MAF to go with the injectors already mentioned would be good too.
I'd be researching torque converters, tranny kits, and additional cooling like crazy too.
Sounds like a bunch of fun though!
