Shifter rattle
Old Apr 16, 2007 | 01:12 AM
sm6989's Avatar
sm6989
Default Shifter rattle
Alright, When you get on the car, and at higher RPMs..the shifter will start to shake really bad. Everything in the tranny is new(only 2000miles) so dont know what the problem is..only notice it at higher rpm's..Everything done to the car is in my sig.
Any idea on what the problem could be?
Old Apr 16, 2007 | 01:14 AM
mattdel's Avatar
mattdel
Default RE: Shifter rattle
bad mounts or bad balancing(harmonic or flywheel)
Old Apr 16, 2007 | 01:15 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Do you notice the shaking anywhere else?
Old Apr 16, 2007 | 01:23 AM
sm6989's Avatar
sm6989
Not really..pretty much just the shifter.
Old Apr 16, 2007 | 01:26 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
What kinda shifter and I assume you've rechecked that right?
Old Apr 16, 2007 | 01:31 AM
sm6989's Avatar
sm6989
It's a steeda tri-ax shortshifter
AdderMk2's Avatar
AdderMk2
Banned
higher RPM's or higher speeds??? if its happening at high rpm;s AT higher speeds.... I would suspect a U-joint in the driveshaft
Old Apr 16, 2007 | 01:33 AM
sm6989's Avatar
sm6989
Seems more like higher rpm's, like if you were to get on it..If your just cruiseing at higher speeds it has some but not as much as if the RPMs were up there.
Old Apr 16, 2007 | 01:38 AM
AdderMk2's Avatar
AdderMk2
Banned
check your mounts, and check your harmonic balancer.... as they start to wear out, you will notice more vibrations in the car
Old Apr 16, 2007 | 02:19 AM
sm6989's Avatar
sm6989
I will...anything else?
