Engine whine
Old Apr 17, 2007 | 11:54 AM
Insnedrmr's Avatar
Insnedrmr
Default Engine whine
Ive noticed on my 87 5.0 when I rev the engine it more or less whines, and drones out the sweet exhuast. I thought it may have been the belts, but they look ok. Any ideas?
Old Apr 17, 2007 | 12:32 PM
Ninety5five0's Avatar
Ninety5five0
Default RE: Engine whine
Take off the belt and start it and see if it still does it. If it doesnt make the noise you prolly got a bad bearing somewhere in one of your pulleys. Is it when your moving or at idle ?
Old Apr 17, 2007 | 02:21 PM
93must's Avatar
93must
Power steering pump?
Old Apr 17, 2007 | 02:22 PM
cassidymustang's Avatar
cassidymustang
ORIGINAL: 93must
+1^
Old Apr 17, 2007 | 02:23 PM
PearlWhiteGT's Avatar
PearlWhiteGT
I'm having the same problem & still can't figure it out. Does it do it at idle or only when you rev it up?
Old Apr 17, 2007 | 02:28 PM
91stang's Avatar
91stang
you sure you don't have a supercharger under there? haha
no but i could be the power steering pump or just time for a new belt
Old Apr 18, 2007 | 10:52 AM
mustang5_0gt's Avatar
mustang5_0gt
it also could be ur clutch in ur fan thats if ur using a clutch fan and don't have electric fans. Mine had the same problem and it was the clutch the barrings were almost gone.
Old Apr 18, 2007 | 11:03 AM
Insnedrmr's Avatar
Insnedrmr
Ive only noticed when the car is parked and in neutral. It seems to happen only when I rev it. My power steering pump may actually be on it way out cause i noticed also when I turn the wheel it whines a little bit. ITs a different sound, but maybe the same thing causing it.
And I dont have an electric fan, how would I go about checking these bearings?
Old Apr 18, 2007 | 11:21 AM
mustang5_0gt
take off ur fan and the clutch should be inside the fan there are a few bolts and u will be able 2 c if ur clutch is good
Old Apr 18, 2007 | 11:33 AM
nacanitihs's Avatar
nacanitihs
does the whine go away when you push the clutch in? cuz it could be a throw out bearing cuz thats whats wrong w/ my car...
