newbie needs help
Old Apr 20, 2007 | 02:33 PM
nickelz44's Avatar
nickelz44
Default newbie needs help
1st of all i'am a newbie and i don't post to many threads because i use the search button and i've found just about everything i've been looking for. This is a great site with alot of good info. But i've checked the search button for help with this. My check engine light came on and i got code 67 Transmission Manual Lever Position (MLP) sensor circuit - Transmissions. Where is this located and how do I do about fixing this? The previous owner of the car hacked all the wiring up, and there was a remote starter that never worked which i removed. Do you think that had something to do with it? My car is 89gt 5speed. Any info would help Thank you
Old Apr 20, 2007 | 02:36 PM
mattdel's Avatar
mattdel
Default RE: newbie needs help
yup.to remotely start a manual car, you need to splice into the clutch switch wiring. sounds to me like when you removed the wiring, you left that wire screwed up, or bare.
Old Apr 20, 2007 | 02:39 PM
nickelz44's Avatar
nickelz44
thanx mattdel for the quick reply...I'll go check that right now
Old Apr 20, 2007 | 02:58 PM
ddeaton66's Avatar
ddeaton66
+1 You have to either connect it back up to the sensor or trick it again like the remote starter did.
Brett Ludlow
Sep 23, 2015 06:59 AM
Natex
May 10, 2004 09:43 PM
hewittpony69
May 8, 2004 08:42 AM
