uneven launch
Cool. Because on a coil over set-up you can adjust somewhat for roll by transferring weight with spring pre-load. You are basically going to have to air bag or anti-roll, or live with the roll. I have seen anti-roll set-ups for less than $300 but I would have to do some e-shopping to find one. Lemme see what I can find for ya. Check your options.
+1 and besides that the anti-roll bar is sort of a one time purchase in the life of the car.
I've always thought it was a little wiser to 'over-build' the chassis than the engine anyway........
You might want to look into eibach drag springs in the rear. You don't use an air back with the moroso trick springs. The passenger rear springs is shorter and stiffer then the driver rear spring or it might be the other way around. Its ment to make the car squat uneven when you preload the suspension like that so it should lauch evenly.
