Need info for computer.
Old Apr 25, 2007 | 08:07 PM
ahittz24's Avatar
ahittz24
Default RE: Need info for computer.
Just get a C&L MAF with the blue sample tube for 24lb injectors.
Old Apr 25, 2007 | 08:14 PM
jrt1990's Avatar
jrt1990
So just to make sure 100%, this is what I need for a car with 24# injectors, E303 cam, and 70mm throttle body:
- 73mm Mass Air Meter calibrated for 24# injectors.
- A9L or A9P (preferably A9L) Computer.
- Aftermarket 89-93 Cold Air Intake or stock tube.
- Mass Air conversion wiring pigtail or wiring harness out of an 89-93.
Does all that look good?
Old Apr 25, 2007 | 08:27 PM
primetime5.0's Avatar
primetime5.0
If your car is an auto you can only run the a9p computer, if your car is a 5spd you can run either, and the only direct swap harness for mass air is from an 89
Old Apr 26, 2007 | 04:58 PM
jasonvri's Avatar
jasonvri
I ♥ Acer
I can't resist this any more...
A9L vs A9P----- You will NOT notice a difference between the 2. IF you are told that there is a noticeable difference then your being fed bs, or the guy telling you this did not allow the adaptive to fully adjust...
It would be best not to run a C&L. They are a crap shoot for proper AFR.
IF you must use a C&L then don't think that it will work with a CAI.
IF you are going to use 24lb injectors, and have to buy a compter and MAF anyway, then just run a 93 Cobra ecu; the X3Z.
You will need the MAF meter (and sensor), computer, and 24's.
You will end up with stock drivability and you won't notice a power difference between the A9* and X3Z.
Drivability of the X3Z with 24's and stock Cobra MAF will most often be MUCH better than drivability of an A9L with 24's and a 'calibrated' MAF.
jason
Old Apr 26, 2007 | 05:11 PM
w8less's Avatar
w8less
ORIGINAL: jasonvri
jason
u decided to come back.....always good to have good info around
Old Apr 26, 2007 | 05:23 PM
jasonvri's Avatar
jasonvri
I ♥ Acer
ORIGINAL: Jasperstang308
ORIGINAL: jasonvri
jason
Only on lunch at work, and I may not be here long...
I am still bothered by the arrogance of the mods, but maybe I can get over it...
jason
Old Apr 26, 2007 | 06:36 PM
jrt1990's Avatar
jrt1990
ORIGINAL: jasonvri
ORIGINAL: jasonvri
jason
jason
Ok thanks so should I see about this, he says he'll include the computer too if need be. http://cgi.ebay.com/ebaymotors/Musta...spagenameZWDVW
Old Apr 27, 2007 | 12:12 AM
jrt1990's Avatar
jrt1990
Anyone?
Old Apr 27, 2007 | 12:40 AM
Joel5.0's Avatar
Joel5.0
Yep....you could buy the MAF-ECM Cobra combo.....BTW.....
This is a Real 1993 Cobra Mass Air Meter. The Sensor Part # is F1SF-12B579-AA (true Cobra sensor). The MAF is a 75mm for 19lbs injectors.
Is wrong....that MAF is calibrated for the X3Z ECM logic, not for a specific injector size, its setting is specifically designed for the X3Z ECM logic "firing" 24# injectors.
Old Apr 27, 2007 | 12:56 AM
jrt1990's Avatar
jrt1990
ORIGINAL: Joel5.0
Ok, thats all I needed, thanks!
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
ChampInSD
Oct 2, 2015 04:55 AM
RCS02v6
Sep 29, 2015 01:46 PM
junior04
Sep 28, 2015 10:53 AM
GLOCKer
Sep 28, 2015 07:36 AM
