Ok...did trickflow mess up and send me two of the same covers, or do I need to make my own hole?
Check it out at Summit...
http://store.summitracing.com/partde...&N=700+150+
No Oil Hole...Guess I have to Drill
i ordered a set of ford racing valve covers but made the mistake to befor carb well dads mistake, so when i do oil changes i take the distributor and then drop the oil there,(getting new ones soon)
or you could feed the oil through the pcv. it would still b a pain in the *** but its easier than pullin the dizzy. as for the new valve covers, i would just send them back and look for a pair on ebay that has a fill tube on them. JMO
convenient lol
I've talked with Trick Flow about this and all you have to do is go to the parts store and get a standard breather and grommet, drill a hole and pop it in. They recommend one on each side. You willl be eliminating the hose that goes from the stock filler tube to the T/B so you must cap off the hole in the T/B.
i have the sameone dont remember doin a whole
