Mark VIII & Taurus fan users
Old Apr 26, 2007 | 09:22 AM
PearlWhiteGT's Avatar
PearlWhiteGT
Default Mark VIII & Taurus fan users
How many of you are running your E-Fan with out a variable speed controller????
Old Apr 26, 2007 | 12:11 PM
r.barn's Avatar
r.barn
Default RE: Mark VIII & Taurus fan users
you dont need one, just make it so it comes on with the key
maybe put a switch on the dash to turn it off for warm up or in the winter.
Old Apr 26, 2007 | 12:45 PM
PearlWhiteGT
I read somw where that someone was using a relay & a Volkswagon Thermal Switch from an early 80's model Rabbit. What do you think???
Old Apr 26, 2007 | 12:52 PM
my77stang's Avatar
my77stang
actually pretty much any auto parts store will sell you a universal electric fan relay kit that will kick it on when the temp gets over whatever the thign is set to (160, 180, 190, etc) they are like 20 bucks and worth the money to have it setup the right way.
how good are these taurus fans anyways? will they cool a 350-400 hp motor? anyone have dimensions of the fan/shrould assembly? pics would be good too
Old Apr 26, 2007 | 01:10 PM
r.barn's Avatar
r.barn
77stang, yes that tarus fan will cool your engine, no problem.
no deminsions, but unless you have a really tight engine
bay it will fit with slight trimming if any.
Old Apr 26, 2007 | 01:20 PM
PearlWhiteGT
What does that universal fan relay kit come with? I need a big relay because the fan draws something like 80 amps at start up. Some one told me to use a 75 amp Bosch relay or a white-rogers relay # 70-111224-5 that can be bought from Grainger & it's 80 amps. It looks like a starter relay. www.Grainger.com
Old Apr 26, 2007 | 01:51 PM
yellow93lx's Avatar
yellow93lx
You will have to put some type of relay for the fan anyway so get a thermo switch from summitracing. They have all different types with different temps for the probe.
Old Apr 26, 2007 | 05:08 PM
PearlWhiteGT
Do I have to use a diode & an inline fuse?
Old Apr 26, 2007 | 06:07 PM
Jfsram's Avatar
Jfsram
Do not let the fans come on before the thermostat opens. Common mistake and it's just a plain waste of electricity.
Old Apr 26, 2007 | 11:24 PM
rsw007's Avatar
rsw007
i run a taurus fan with a bosch 75 amp relay and a adjustable temp switch from advance auto parts.
BOB ROME
Jul 26, 2023 01:54 PM
baddog671
Jul 26, 2016 01:20 PM
BeatnikFink
Oct 1, 2015 08:00 PM
