car wont start Help
ok car sat for about a week, and when i went to start it the batt was completely drained. So i jumped it and drove the car to the stang meet down here. wen i went 2 leave the batt was completely drained again. jumped it again and disconnected amp and speakers and all that. Next morning car wouldnt start again. b4 it sat for a week car would start fine, volts are reading a good reading. is ther sumthin i should check right off the top, or just go thru electrical tryin 2 find sumthin thats drainin the batt?
car has new batt, sn95 alt
ORIGINAL: 93stallion302
It takes a knowledge of electricity to be able to solve a problem like this. Unless, of course, it's something obvious. The alternator could not be charging. You could have bad cables. A bad ground. It could be a million and one things. The first step, if you think it's a drain, is to perform a parisitic drain test. Then you'll know whether it's a charging problem or drain problem. The battery could be bad too.
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
