Problems with my cam
Old May 7, 2007 | 02:26 AM
gizim_1132's Avatar
gizim_1132
Default Problems with my cam
Alright I posted a thread earlier and I couldn't find anyanswer on what it would be but I put a crower stage 2 cam in the stang this winter and when I went to pull it out it would not go past 5500 rpms like there was some kinda rev limiter or something any suggestions would be appricated!
Old May 7, 2007 | 02:37 AM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: Problems with my cam
still using stock heads?
Old May 7, 2007 | 02:38 AM
rcdblink716's Avatar
rcdblink716
Valves aren't adjusted correctly. Readjust the valves. They are probably too loose
Old May 7, 2007 | 02:41 AM
67mustang302's Avatar
67mustang302
Did you get matching valve springs? Sounds like it could be valve float, do you hear any metallic type rattling or banging at around 5,500?
Old May 7, 2007 | 02:45 AM
gizim_1132's Avatar
gizim_1132
yes they are the stock heads and yes I did change the valve springs and I can't hear anything when 5500 rpms comes around it just bogs down
Old May 7, 2007 | 02:50 AM
AdderMk2's Avatar
AdderMk2
Banned
bogging down, definitly sounds like valve float
rcdblink716
I dunno if that head can take much lift. How big is that cam. I'm surprised you haven't bent a pushrod. It takes more than just valve springs for a head to handle high lift. There is machining involved for clearance. Definitely float though. If the heads can take the lift then I think you need to readjust the valves. That could be causing the float.
Old May 7, 2007 | 02:54 AM
Evil_F's Avatar
Evil_F
Trying to use a stock ECU with a big cam? Probably running lean, preventing upper rpms. May have spark issues.
Old May 7, 2007 | 03:08 AM
gizim_1132's Avatar
gizim_1132
Well it was for a 289 the guy said it would work fine but we later found out that we had to change the firing order and then somebody on here said the fuel injectors wouldn't be working right
Old May 7, 2007 | 03:15 AM
rcdblink716
Haha. Hell ya the 289 and late model 5.0 have different firing orders. It's like a chevy 4 7 swap. The injectors are off. You are going to have to compare both firing orders and swith the injector connectors for the cylinders that switched in firing order.
