Rear diff fluid
Old May 7, 2007 | 10:35 PM
watson30's Avatar
watson30
Default Rear diff fluid
How do you refill the diff?
thanks
Old May 7, 2007 | 10:38 PM
tmajikman's Avatar
tmajikman
Default RE: Rear diff fluid
There is a plug in the upper side of the diff housing on the drivers side, use a 3/8 ratchet and loosen the plug. Get some type of pump to put the 80/90 weight in the diff.
Old May 7, 2007 | 10:41 PM
watson30's Avatar
watson30
thanks man, should I be able to see it from the wheel well?
Old May 7, 2007 | 10:44 PM
thunderjet429's Avatar
thunderjet429
no... you have to be at the center section.
Old May 7, 2007 | 10:46 PM
tmajikman's Avatar
tmajikman
no..... you will need to jack up the car and look at the diff where it is connected to the driveshaft, look up above the driveshaft to youright a bit. I had to feel for the plug the first time I tried to find it, use a light as well, it will help..... Use a hydraulic jack as well. Just don't want you to get hurt with the wimpy jack that came with the car.
Old May 7, 2007 | 10:50 PM
thunderjet429
and use a jackstand and wheel chalk... be safe
Old May 7, 2007 | 11:00 PM
tmajikman's Avatar
tmajikman
very true
Old May 7, 2007 | 11:08 PM
90Lxstanger's Avatar
90Lxstanger
here a ****ty piv if you have problems find the fill plug, and be careful and good luck(i never ues a jackstand)IM very smart too[8D]
Old May 7, 2007 | 11:54 PM
watson30's Avatar
watson30
piv or did you mean pic?
90Lxstanger
Picture, sorry, bad spelling sometimes
