90 vert with C4
Hi all,
Here's my problem, I have a 90 GT vert and they guy that owned it before me put a C4 trans in it which has been giving me quite a bit of issues even after all the seals and such have been replaced [:@] I want to go back to the AOD but I'm not quite sure what else I'm going to need besides the trans, kinda shooting in the dark cause I really don't know what was modified to put the c4 in. Any help would be really appreciated
Thanks,
Jason
Thanks,
Jason
i think the c-4 and fords AOD are interchangable as far as monting points, give the bellhousing is for a SBF, cross member should be fine, slip yoke should be ok also, and i dont have a clue about the shift linkages. GOOD LUCK
the AOD uses a throttle valve or TV cable to control the trans pressure so you need one of these and a cable type shifter to shift the gears as it doesn't use a linkage system per se. you can probably get them from a salvage yard.
YoungStangsMan
Sep 5, 2015 07:01 PM
