Rear shocks
Old May 9, 2007 | 06:43 PM
Force4's Avatar
Force4
Default Rear shocks
I cant get my rear shocks off from the top. I cant seem to get a vice grips to hold back the fricken shaft from spinning with the wrench any ideas??
Old May 9, 2007 | 07:37 PM
Force4's Avatar
Force4
Default RE: Rear shocks
bump i cant figure this out for the life of me!
Old May 10, 2007 | 12:37 AM
nyfreakinrican7's Avatar
nyfreakinrican7
I haven't seen a factory shock on the mustang but on my crown vic i cut the outer part of the shock with tin snips then I had room to lock my vise grips on the shaft.
Old May 10, 2007 | 12:39 AM
frankbullitt's Avatar
frankbullitt
spray some wd40 on the nut. Mine came off easy.
Old May 10, 2007 | 12:40 AM
frankbullitt
now that i think about it it should have a slit to place a flat head so you can spin it with a wrench.
Old May 10, 2007 | 12:44 AM
90_Mustang_GT's Avatar
90_Mustang_GT
the vice grips and wrench is how i got mine off....but i did spray it with 1st aid rust penetrant
Old May 10, 2007 | 12:47 AM
92hatchLX's Avatar
92hatchLX
Use an impact wrench on it, you won't even have to hold anything, just the trigger
Old May 10, 2007 | 05:14 PM
Boss_Hotrod's Avatar
Boss_Hotrod
I was able to get them off with a ratchet with someone holding the bottom under the car. I had to use an impact to get the new ones snug enough.
guitarman376
Oct 11, 2015 01:47 AM
67STANGX2
Sep 24, 2015 12:29 PM
Sep 16, 2015 07:53 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 1, 2015 08:16 PM
