ADVICE!!!!!!
Old Dec 16, 2004 | 12:24 AM
jgsfoxbody's Avatar
jgsfoxbody
Default ADVICE!!!!!!
Hey folks this is my first post on here so hopefully i wont make a fool of my self....this is what i have...an 87 with a 347 stroker, vic jr heads, trackheat intake, dual flowmaster exhaust wit no cats, c-6 tranny, stock gears, hurst shifter, 75 mm maf, 30lb injecters, cold air...um thats bout it...most of this stuff is layin around the shop till i decide on a header and cam...nebody have advise on the numbers ill be making with this setup or recomendations on headers, cams or torque converter...thanx
Old Dec 16, 2004 | 03:29 AM
StangTangGT's Avatar
StangTangGT
Default RE: ADVICE!!!!!!
call comp cams and they will custom grind you one for your setup. um i dont remember how much hp the 347 makes over the 302, but im sure the torque convertor will depend on how many ponies your runnin in the end. Sounds like a sweet setup though!
Old Dec 16, 2004 | 04:36 PM
jgsfoxbody's Avatar
jgsfoxbody
Hey man thanx for the reply...um i think the final number with a decent cam and stuff should be around 500...nebody got nething like this that might can give me a time estiment or nething like that
Old Dec 16, 2004 | 05:56 PM
4fit?'s Avatar
4fit?
Not sure on the ponies, but get them stock gears out of there! 347 with stock gears makes baby jesus cry.
Old Dec 17, 2004 | 02:05 AM
roundman's Avatar
roundman
ORIGINAL: jgsfoxbody
I doubt that you will be getting 500 HP out of it unless you have high compression and a really good cam sized to work with the heads and intake you say you have. and the C-6 tranny will eat up a good amount of that HP before it ever gets to the rear wheels. a built C-4 or AOD would be a better choice of tranny IMO.
Old Dec 17, 2004 | 10:50 PM
jgsfoxbody's Avatar
jgsfoxbody
Yeah i been told my tranny will hurt me...but its been built if that makes nedifference...im gonna go with 373 gears b/c i wanna keep it street strip...the compression is about 10-1...i bought an aluminum flywheel and an aluminum driveshaft so that should help some gettin some more power to the wheels...neone else all opinions are welcome thanx
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
