AOD Problems
Old May 10, 2007 | 11:52 PM
mikeisgod's Avatar
mikeisgod
Default AOD Problems
My friend has a 90 GT that he just about 2 weeks ago put a transmission in from a 91' GT to replace his bad one. It has worked fine for the past two weeks and now all of a sudden it just wants to shift through all the gears... It will not stay in what gear it should, it just goes right through the gears... Any idea why it would do this? His old boss (the guy he got the tranny from) suggested it could be a vacuum leak, and his friend suggested it could be the kick-down cable.... Either of these sound likely? Thanks
Old May 10, 2007 | 11:57 PM
mattdel's Avatar
mattdel
Default RE: AOD Problems
detent(TV) cable, fix it SOON or you WILL be replacing the trans again
Old May 11, 2007 | 12:13 PM
luckythirteen13's Avatar
luckythirteen13
sounds like the TV cable to me. dont drive it till you make sure the tv cable is adjusted/working correctly
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
