3.90s
Old May 17, 2007 | 12:31 AM
dimebag's Avatar
dimebag
Default 3.90s
any MANUAL tranny guys running these? i no one or two of yall auto ppl use them. but im askin for manual guys... what i need to know is, how tall of a tire you run, and what rpm you cross the traps in... thanks
Old May 17, 2007 | 12:33 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: 3.90s
Is this gonna be like your tire threads? I'm gonna slap you if I see you this weekend!!!
Old May 17, 2007 | 12:34 AM
PX429's Avatar
PX429
Default RE: 3.90s
why waste your money. If your going to run 3.90's just run 4.10's
Old May 17, 2007 | 12:36 AM
dimebag's Avatar
dimebag
Default RE: 3.90s
na man wont be like my tire threads, i promise
and 4.10s are putting ppl on a stock tire thru the traps at 6100, i want it slightly lower, hopefully in the 5500 range...
Old May 17, 2007 | 12:38 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: 3.90s
I think I was trappin somewhere around 5400 - 5800 w/ 3.73's and a 26" tire.
Old May 17, 2007 | 12:39 AM
PX429's Avatar
PX429
Default RE: 3.90s
ORIGINAL: dimebag
Exactly! You want to be at the top of fourth at the end of the track.
Old May 17, 2007 | 12:41 AM
dimebag's Avatar
dimebag
Default RE: 3.90s
really pro? damn... buddy of mine traps either 6xxx in 3rd, or bottom of 4th w. his 3.73s
and yes i want to be at the top, but not 6100 where im not making power, power dies off around 5500 as you know, id rather go thru there, then higher... worse comes to worse ill get 4.10s and a slightly taller tire if need be
Old May 17, 2007 | 12:42 AM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: 3.90s
ORIGINAL: dimebag
thats because your buddy isnt running a procharger
Old May 17, 2007 | 12:48 AM
dimebag's Avatar
dimebag
Default RE: 3.90s
makes sense, but theoretically, w. the same gear and tire, shouldnt both cars have the same rpm at =places? i no pro would get there much faster, but wouldnt the rpm be the same? obviously not, explain....
Old May 17, 2007 | 12:51 AM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: 3.90s
ORIGINAL: dimebag
technically... no
its the same as why one person can run 100mph in the 1/4 and only pull 14.1 seconds. and someone else will run 13.5
