dash lights
Old May 18, 2007 | 12:03 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default dash lights
where exactly do i find the power wire for lights that or ground wire. i check the fuse. none of my gauges light up at night when i turn on my head lights but the blink light and high beam light and volt warning thing and all that work as far as the light in the gauge cluster and the gauges work......just no lights. i checked the fuses....nothing.
im at a loss plz help
Old May 18, 2007 | 12:38 PM
samseed101's Avatar
samseed101
Default RE: dash lights
did you check both fuses for the cluster lights?
Old May 18, 2007 | 01:07 PM
ryanworrell520's Avatar
ryanworrell520
If you are talking about the illumination lights, I may have a diagram of the two sets of cables that connect to the cluster. Let me look
Old May 18, 2007 | 02:47 PM
Twisted's Avatar
Twisted
If you have an aftermarket stereo unit in your car, check to see what the installer did with the dimmer wire that went to the stock radio. If he didn't handle it properly, you'll have no dash lights.
Old May 18, 2007 | 02:54 PM
7upedition's Avatar
7upedition
Have you checked the dimmer switch?
Old May 18, 2007 | 06:48 PM
FivePointOhh
in limbo
havent checked dimmer switch. no aftermarket stereo in it yet(still havent got it in) and if i could get the diagram for the power wires for the dash lights. i have check all fuses in the panel...only one was blown and it was for the windshield wipers which was no brainer cause when i needed them i didnt have them ahhahah. thats when i decided to check them all.
Old May 18, 2007 | 07:04 PM
ryanworrell520
here you go. this should be the wiring diagram for instrument cluster for 87-93 mustang.
folivier
Oct 2, 2015 05:34 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Sep 25, 2015 09:06 AM
accarter
Sep 21, 2015 11:56 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
