engine swap
Old May 20, 2007 | 06:29 AM
83_stang's Avatar
83_stang
Default engine swap
I'm up grading from a 5.0 to a 351, can I use all the same engine parts on the new block when I swap it over?
[IMG]local://upfiles/69710/53898D6AEC8C40558CEC785F835D832A.jpg[/IMG]
Old May 20, 2007 | 08:13 AM
preciousroy's Avatar
preciousroy
Default RE: engine swap
you need new headers, an oil pan and pickup, and a spacer behind the crank pulley to line it up w/ the mustang accessories. oh, you need a 351 flywheel or flexplate too, different imbalance than 5.0l
Old May 20, 2007 | 10:14 AM
AdderMk2's Avatar
AdderMk2
Banned
and a different lower intake manifold.... also dont expect much from the stock 351w heads
Old May 20, 2007 | 01:04 PM
r.barn's Avatar
r.barn
swap is pretty easy, can reuse access with right brackets
plus what they said
Ford Racing makes nice swap pan and brackets
and tons of people make swap headers
Hood clearance will be an issue too.
and +1, plan on upgrading heads, cam and intake to see
and real power.
Old May 20, 2007 | 05:24 PM
jasonvri's Avatar
jasonvri
I ♥ Acer
I believe the dist. will use a larger oil pump driveshaft, so a new dist. will be required...
I have a writeup on doing an EFI 351w swap on my site...
It may still be helpful for you...
jason
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
