Here we go again
ok so in attempt to getting my distributor in and set properly the oil pump shaft fell into the oil pan. What a joy this is going to be. Anyone ever had to take off their oil pan with the engine still in? Advice? Thanks!
it can be done.
its hard, but it can be done.
your going to need to lift the motor up as far as you can get it, while it is still in.
remove all the pan bolts.
after the pan has dropped a couple inches, you need to remove the oil pump pickup tube. it's bolted to the pump with 2 bolts, and there is 1 bolt holding the tube to the #3 main cap on the crank.
you do not need to unbolt the pump itself.
after those 3 bolts are removed, the pickup tube will drop into the pan.
after that, you should be able to wiggle and manuever the pan out.
ORIGINAL: 15austin
Did you not have that clip on the oil pump shaft that prevents it from falling?
ORIGINAL: 88MustangGX
?? im sorry i don't know what you mean by that. The distributor would not set in properly. The shaft would line up but it wasnt down far enough for the teeth to grab. Had about an inch to go. So we pulled up the shaft with a magnet to make sure it wasnt bent or anything and dropped it back in and it was no where to be found when we took out the distributor. My *** up so yea.
ORIGINAL: 15austin
