that red , green, orange wire thing...I broke it??..
Old May 21, 2007 | 11:18 PM
mustang50mike's Avatar
mustang50mike
Default that red , green, orange wire thing...I broke it??..
While fighting with my corroded spark plugs, I managed to break a wire. Here is the funny thing. It is hollow? This is a harnass coming out of the passenger side fender. It goes under the mass air flow, leading to the the center are of the engine. It is possibly not a wire though as it appears hollow?? I broke the red one. It does not feel like a wire either, as it is a hard plastic. I basically just nicked it, and she snapped. I have no idea qwhat it is for, but the car still runs fine...I will try and post a pic. Any ideas what this red thing is for?
Old May 21, 2007 | 11:23 PM
5.0liter_rice_eater's Avatar
5.0liter_rice_eater
Default RE: that red , green, orange wire thing...I broke it??..
i think those are vacuum lines my friend.
Old May 21, 2007 | 11:24 PM
notch5oh's Avatar
notch5oh
vacuum line, you can fix it with some small fuel line
Old May 21, 2007 | 11:27 PM
5.0liter_rice_eater
Did you brake it where that piece of duct tape is? It might be a pain if so, but you can buy a piece of small hose to splice in there and fix it.
Old May 21, 2007 | 11:35 PM
93 LX FiveO's Avatar
93 LX FiveO
electrical tape
i got about 6 vac lines being held together with tape
even the one off my EGR broke, got a CEL.. taped it... no more CEL
Old May 22, 2007 | 12:05 AM
Squirrel_Masta's Avatar
Squirrel_Masta
Get some aquarium hose and super gluefrom wal-mart. Put a drop of glue on the factory vacuum line and slide the aquarium hose over it.I have replaced all of my vac lines this way,I cut themoff about a half inch from where they come out on both sides. no problems yet. Make sure you do them one at a time as to not mix them up.
Old May 22, 2007 | 12:07 AM
mattdel's Avatar
mattdel
run a whole new line and eliminate the plastic POS's.
they will keep breaking on you. better off to fix it once and be done with it.
Old May 22, 2007 | 12:21 AM
CrazyCobraSpeed's Avatar
CrazyCobraSpeed
its a vaccum hose... the proper way to fit it is either to run new line or get a splice connector you that size tubing... if u wanna half a$$ it tape or a sodder would work... but hte sodder is hard and its a special sodder tip newayz... ahve it at work of the robots... we dont like ot do it inless neccesary tho
Old May 22, 2007 | 12:23 AM
creekrat's Avatar
creekrat
they go to the TAD and TAB relays, they also carry vacuum, so make sure they are not leadking! Last thing you need are vac leaks!
Old May 22, 2007 | 04:19 AM
getafewlives's Avatar
getafewlives
Ha ha i broke some the other day. Heatshrinked the babys then taped em. Good as new.
